لجهاز HTC 10 روم ROM 09/12 Viper10 4.2.0 | 2.28.401.9 ◦ Tweaks | HUB | OTA
[COLOR="DarkRed"]ألروم المميزة للجهاز HTC 10 المميز
روم Viper10 3.2.0 | 1.95.401.3 ◦ Tweaks | HUB | OTA [/COLOR] [COLOR="White"]. . .[/COLOR] [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/16120936pm-1171757-240837-0-0.png[/IMG] [COLOR="White"]. . .[/COLOR] الروم المطبوخ الأكثر تعديلا ومرونة قام عليها مجموعة من المطورين المتميزين ليخرجو هذة الروم الرائعة الروم تتميز بمرونه عالية لكثرة التعديلات عليها كما تتميز بإستقبال أشعارات التحديث الهوائي OTA [COLOR="Blue"][U]جديد التحديثات[/U][/COLOR] [CODE] Viper10 3.2.0 (2nd October) Additions & Updates Venom HUB Web Store opened! (VenomHUB Desktop) Browse all VenomHUB content on your desktop browser Download apps, themes and addons to your desktop Install apps, themes and addons from your desktop browser directly on your device(like it works with the play.google.com) Addons, themes and other items can show linked items(f.e. you will see if some addons are compatiable with theme) Minor UI improvemnets in WEB HUB and in HUB App Add "Clear recents apps" mapping to button actions and three finger gesture Add doubletap statusbar action to scroll content to the top Disable Vibration system wide Allow haptic feedback during powersaver Set media volume as default when using the volume rocker Removed VZW disabled data message when toggling and on boot Fixes & Cleanups Fixed HTC Music FC when using HTC car app (full rom only) Viper10 3.1.0 (19th September) Additions & Updates Temperature Infoline Battery CPU GPU Thanks for the extra work you sons of murricans. Supports Fahrenheit - Setting is pulled from the HTC Weather app. Theme Brigthness Slider Slider Thumb Autobrightness button Extended Wifi,Bluetooth and DND Settings Panel are getting themed now Fixes & Cleanups Fixed Visual Theming FCing when the header wasn't reorderd once Header clock color can be applied now without setting an HTML preset Added required statusbar reboot for some visual theming items Viper10 3.0.0 (6th September) Additions & Updates Rebased on 1.95.401.3 Visual theming - Tap item to change its color Notification area: Header, Horizontal Quicksettings, Notifications, Weather Native Quicksettings Volume Dialog Configure update interval of traffic icon Option to disable Notification LED (useful if you use button light notifications) Option to disable LED's when on DND (Notification LED and Button Lights Notification LED's) Option to disable Charging LED on DND Fixes & Cleanups Fixed signalstrentgh not showing for cdma phones - damn murricans always need an extra wurst Fixed button light notification led getting stuck on "On State" sometimes Fixed custom autobrightness "Normal" Profile not applying in VenomTweaks Viper10 2.9.0 (26th August) Additions & Updates Toggle to prevent camera acquiring maximum screen brightness when opening it Signal strength icon for statusbar dBm or ASU level option Custom color Added CM ScreenRecorder App ScreenRecorder Tile to start/stop screen cast Fixes & Cleanups Fixed some shortcuts not working for the Sense Home Menu Fixed notification background color not applying Fixed "Add to home" FC on Sense Home Menu Viper10 2.8.0 (18th August) Additions & Updates Additional animations scales in Settings->Developer Options->Advanced Collapse Statusbar when pressing a quicksettings tile Color background of brightness slider mirror Color brightness slider thumb Option to hide labels in the appdrawer Infinite scrolling on homescreen Increased default power doublepress interval to 300ms, so you slow old guys can trigger the camera action more easily Add additional option to add shortcuts into the Homescreen menu. Shortcuts = direct call, bookmarks etc. Fixes & Cleanups Fixed hidden app labels on homescreen appearing again after reboot Fixed crash when enabling "Hide Navbar on press" option without setting keys to hide it Some minor fixes in VenomTweaks Viper10 2.7.0 (6th August) Additions & Updates Merged with 1.90.401.5 base Button brightness: Allow all values for each sensor value Added Operator Infoline Added quickstart camera with doublepress Power on screen off - Thanks for the suggestion @bearclaw76 Added Power double press interval Added Charging/Low Battery LED to turn off when the screen is on Added toggle to disable/enable button lights on the fly Custom Camera Image names Set a custom prefix (instead of 'IMAG') Append timestamp: Either choose from some prefix or set your own Fixes & Cleanups Fixed hiding Wi-Fi Calling icon Hopefully fixed total crash when playing with custom autobrightness - sry. Viper10 2.6.0 (28th July) Additions & Updates Rebased on 1.90.401.3 Updates Sense Home to 8.14.781908 Android Security Patch Level from July 1st, 2016 16s exposure time Lags are gone after reboot it seems ...lets wait for the official changelog (-: Custom Autobrightness Change the brightness for different light sensor levels It's possible to decrease the minimum autobrightness by 10%! from (30 to 1 on lowest light sensor setting) Customize the brightness value for each sensor level yourself Add/Edit Light Sensor Levels It's even possible now to add more sensor levels if the given ones do not please you Makes it possible to adjust the brightness values better to different light conditions Hide Weather on LockScreen Fixes & Cleanups Fixed JB Toast Style Toggle Fixed Dim BLN - LEDS will blink with full brightness now Restored original Traffic Icon Location Fixed positioning of Venom Battery Text Viper10 2.5.0 (19 July) Additions & Updates Notification ScreenOn List Works the same as ambient display, just that it turns the screen completely on and that you will be able to open the notifications Flash and Buttons blink notifications On incoming notifications either your flashlight or capacitive buttons start to blink on selected apps Additional settings Blink speed Repeat timeout Blink timeout Intercept mode Screen on Flip device (required when you use it for incoming calls) Seperate Left, Right and Full Width Quick Pulldown Two fingers Gesture Quick Pulldown Hide quicksettings expand/collapse button Full width header, quicksettings panel and notifications Remove padding between notifications Color options for notifications Background Title Text (colors, the notifiation text, time, action icons and text) Icon circle background Icon HTC Connect HEQS Notification and LED tweaks got their own tab now in VenomTweaks Fixes & Cleanups Fixed traffic indicator being visible even is data connection is not available Fixed battery text not displaying correctly Fixed traffic icon showing even when data was off Fixed traffic indicator not showing on lockscreen Viper10 2.3.0 (13 July) Additions & Updates Pulldown Gestures Updates Change Gesture color Use shortcuts to start custom activities, direct calls, etc. Custom volume steps (45 max) - Makes it easier to fine tune the volume with your volume buttons STREAM_VOICE_CALL STREAM_SYSTEM STREAM_RING STREAM_MUSIC STREAM_ALARM STREAM_NOTIFICATION STREAM_BLUETOOTH_SCO Put Signal icons on left Notification LED Blacklist Select the apps you don't want to flash the LED on a new notification Venom Battery text moves to left now too when battery on left enabled Contextual Header and Recent Apps Set time based backgrounds (morning, afternoon, evening, night) images for your header and recent apps Use predefined or custom images Random mode HTC Connect Quicksettings Tile Custom Ambient Screen Brightness (255 steps) Tweaks Backup and Restore (It takes a while the first time to show app - Patience!) Backup options Internal SDCard VenomHub Server or Google Drive Google Drive is used for backup and restore (Enables you to easily restore settings across different devices) Fixes & Cleanups Fixed battery on the left when using stock battery Fixed right margin on stock battery when using it on the left Fixed double tap statusbar to sleep Fixed delay of back and recent button when no doublepress action is set Fixed Bluetooth Tile showing wrong state Fixed ANR that caused a freezed headsup and statusbar Fixed VenomTweaks opening discontinued Ticketsystem - Opening integrated IRC Chat support instead now Viper10 2.2.0 (01 July) Additions & Updates Headsup notification for incoming calls Just shows when screen on Option to dismiss the incall notification Compatible mode (For some US carriers they don't show by default) Hide Bluetooth Disconnected Icon Hides the icon when no device is connected. Once one is, the Icon will appear Pulldown Gestures draw gestures to peform different actions Reveal with quickpulldown, three finger gesture or button mapping Move Battery to the left Allow home button during calls Option to quickpulldown quicksettings on full width of the statusbar Horizontal Quicksettings Sync All and Toggle Sync button New Tiles Sync Tile Sync All Tile SilentMode Tile VibrationMode Tile ADB Wi-Fi Tile Screenshot Tile Invert Volume Cursor Control Keys Keep Display off when unplugging charger Allow all rotations Ambient Display Additions Whitelist: Enable Ambient Display just for specific apps Pulse Once Pulse Visible Duration Pulse Fade In Duration Pulse Fade Out Duration Pulse Shedule Updated to latest Sense Home Add custom bootanimation option Add custom downanimation option Add custom bootsound option Ficksed mei tipos ant crammatical erors in fenom tweeks. Credit @Basil3, @NotATreoFan, @Kratos90 Fixes & Cleanups Fixed Headsup timeout not showing correctly in VenomTweaks Fixed graphical glitch when pulling statusbar the first time Fixed haptic feedback on longpress Fixed Enable Bootsound toggle Fixed system r/w toggle Viper10 2.1.0 (20th June) Additions & Updates Added Headsup notification control Black and Whitelist Blacklist allow all Whitelist ignore score Prevent headups on specific apps (e.g. youtube, when you watch a video) Headsup timeout Added LED Battery Full Toggle Added LED Battery Charging Toggle Added LED Battery Low Battery Configuration Added Glove Mode Tile and Horizontal Quicksetting Added back Ambient Display Added extended navbar for venomnavbar Added Recents Task Hide Clear All Button VenomHUB New Categories Themes Bootanimations Navbar Themes IRC Support Fixes & Cleanups Fixed DND and Rotation Tile Fixed Hiding USB Notification Fixed Headsup notification toggle Fixed Updating in VenomHUB Viper10 2.0.0 (15th June) Additions & Updates Rebased on 1.80.401.1 - All carriers working Added option to remove haptic feedback when unlocking with fingerprint sensor Remove haptic feedback from capacitive buttons when Navbar is enabled Added option to keep home button working when using Navbar Added option to keep both, capacitive buttons and navbar (amazing with extended navbar) managed to keep button backlight working, yay Added option to hide redundant "Buttons" panel in extended navbar, if used together with capacitive buttons Added option to select default view for extended navbar Added option to swap up/down traffic info Added Russian translations for Sense Home Menu Added customizing color of the volume dialog Background Icon Expander Active and Inactive Slider Added 'Keep collapsed header' option when expanding the quicksettings Added toggle to disable headup notifications Added option to disable buttons and backlight when navbar is active Fixes & Cleanups Fixed headsup notification toggle Fixed tiny icons in quicklaunch on extended navbar Fixed brightness slider not changing icon when toggling automatic brightness on extended navbar Fixed hiding VZW Wi-Fi Connected Notification Viper10 1.5.0 (12th June) Additions & Updates (Fullrom only) Aroma option for SuperSU compatible mode fixed (Fullrom only) Aroma option to use decrypted data (needs format data before) - Thx @squid2 for the cleaner solution Fade out Page Indicator on Homescreen Hide vzw connected wifi notifcation Added "Always/Just Once" Option to native USB Configuration Dialog Show External SD-Card in Infoline SEPolicy Enforce option Changing navbar styles work on the fly without rebooting Venom and Stock Navbar Custom Navigationbar height on the fly Auto Hide Navbar after a specified time VenomNavbar Background colors VenomNavbar Activation area colors VenomNavbar Custom Activation area size VenomNavbar Activation Type (Touch or Swipe) Touch anywhere to hide Press Key to Hide Longpress Key to Hide Extended Navbar - add different panels to your navbar, swipe left/right to switch Available panels: Music controls, quicksettings, quicklaunch, extended buttons, brightness slider Infinite swiping Swipe and animation direction Swipe distance Setup Extended buttons, quicklaunch and quicksettings Fixes & Cleanups Fixed longpress Home/Recent Screen Off action causing next single press to work just on 2nd press Fixed Theme Info dialog causing out of memory errors for some icon packs Fixed Customize Statusbar per app colors Fixed RAM Info line not matching recent apps ram info Viper10 1.4.0 (7th June) Additions & Updates Homescreen 4x5 layout Hiding quicksettings now gives the space free Ability to make Wi-Fi and BT Tile taking same space as other quicksettings Custom Quicksettings Column Size 4-12 Quicksettings custom tile size Quickpulldown Left, Right, Both New Sense Home from Playstore New Camera from Playstore Fixes & Cleanups Fixed Messages FC on MMS for TmoUS Fixed Recent App RAM Display not sticking after reboot Viper10 1.3.0 (5th June) Additions & Updates VenomHUB Revert back to list menu on main screen Reworked FAQ section Expandable items Added search Volume cursor control Statusbar traffic info with up and down Blink LED while charging Ambient display Hide slow charger notification Hide low battery notification Hide search in recents apps Recents apps with RAM Display 5 or 6 columns in folder Center folder Enabled Call Recording Russian translations in SystemUI and Prism Fixes & Cleanups Fixed Sprint Icon Theming Fixed custom lockscreen weather location picking wrong city Fullrom only: Fixed Verfied Boot (Require PIN on boot). Credits @nkk71 Viper10 1.2.1 (28th May) Fixes & Cleanups Fixed installation issues, that caused bootloops Viper10 1.2.0 (26th May) Additions & Updates Working Android Pay (Fullrom only) Added GPS Tile Added Caffeine Tile, Credits Cyanogen Added Hide Dock on blinkfeed Added 5x6 Appdrawer Updated Sense Home Fixes & Cleanups Fixed recent apps not being remappable when using softkey navbar Fixed 3 finger tap gestures Fixed longpress home remapping when using softkey navbar Full ROM Only Switched to systemless root Android Pay tested and works on all carriers AdAway now works systemless (in order to make Android Pay working) Added SuperSU compatible mode option in Aroma (WILL BREAK ANDROID PAY!!) Added HTC Car in Aroma Fixed TMOUS WiFi Tethering Viper10 1.1.0 (24th May) Additions & Updates Added NEQS Hide Reorder to VenomTweaks Added Tweaks and HUB NEQS Tile Added Powersaver NEQS Tile Added Facebook removal option in aroma installer Added NFC NEQS Tile for all users Disable Hardware Keys when enabling navbar Fixes & Cleanups Fixed brightnesslider tile reappearing after toggling DND tile Fixed VenomHUB purchases. Fixed Battery theming Fixed prev/next track 3 finger gesture Fixed System Info Circles overlaying Wifi, Bluetooth, DND Pulldown Fixed FC of HEQS Hide Reorder Dialog on Vodka language Fixed Neqs tweaks not enabling/disabling properly when disabling neqs Fixed Sense fcing when clicking the weather icon in blnkfeed Fixed Verizon and Tmous signal icons selection New high res default heqs and APM icons Viper10 1.0.0 (22nd May) Additions & Updates Intial HTC 10 Release Based on 1.30.401.1/1.53*/1.54 VenomTweaks comes with it's full force! New VenomHUB, including a web frontend! System root(SuperSU 2.74-2) pre-patched (Apps like ES works!) Updated aroma installer graphics, menus, and removal/install options Full carrier support with working WIFI calling and VoLTE(those that support it) T-Mobile Verizon Sprint Removed various system loggers HTC Camera app and system drivers update from 1.54* base with JPEG 100% qulity tweak(MISC tab in Tweaks) Added missing 7 sense Apps&Widgets as aroma install option [/CODE] [COLOR="White"]. . .[/COLOR] بعض صور الروم [COLOR="White"]. . .[/COLOR] VenomHUB [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/16120936pm-1171758-240837-0-0.png[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/16120936pm-1171759-240837-0-0.jpg[/IMG] [COLOR="White"]. . .[/COLOR] فيديو يوضع بعد تعديلات الروم [url]https://www.youtube.com/watch?feature=player_embedded&v=FZtvdA0wRW0[/url] [COLOR="White"]. . .[/COLOR] تعديلات NavBar [url]https://www.youtube.com/watch?feature=player_embedded&v=A1MMa0oaU_g[/url] الإيماءات [url]https://www.youtube.com/watch?feature=player_embedded&v=sKyzR0Xj9cI[/url] [COLOR="White"]. . .[/COLOR] بعض مميزات الروم [COLOR="White"]. . .[/COLOR] [url]https://www.youtube.com/watch?feature=player_embedded&v=DdyQmDPc9qc[/url] [url]https://www.youtube.com/watch?feature=player_embedded&v=OUuAQX55V9o[/url] [COLOR="White"]. . . . . .[/COLOR] [URL="http://venomroms.com/viper10-dowloads/"]رابط تحميل الروم [/URL] رابط الروم بموقع المطورين [url]http://forum.xda-developers.com/htc-10/development/rom-21-02-viper10-1-0-0-tweaks-hub-t3379151[/url] ملحوظة : إذا كان جهازك غير مفكوك الحماية . تحتاج الإطلاه على هذا الموضوع لتتمكن من تحميل الروم [url]http://www.ce4arab.com/vb7/showthread.php?t=627023[/url] |
[CENTER][COLOR="Red"][B]مشكور اخوي على المجهود
هل الروم يدعم عربي[/B][/COLOR][/CENTER] |
[QUOTE=empcco;5092424][CENTER][COLOR="Red"][B]مشكور اخوي على المجهود
هل الروم يدعم عربي[/B][/COLOR][/CENTER][/QUOTE] العفو أخي الكريم لا أستخدم الواجهة العربية ولكني قمت بالتأكد وهاهي تدعم العربية كما في موضح ادناه [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/18021243am-1171831-240837-5092424-631810.jpg[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171832-240837-5092424-631810.jpg[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171833-240837-5092424-631810.jpg[/IMG] [IMG]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171834-240837-5092424-631810.jpg[/IMG] |
[QUOTE=mh7;5092438]العفو أخي الكريم
لا أستخدم الواجهة العربية ولكني قمت بالتأكد وهاهي تدعم العربية كما في موضح ادناه [url]http://www.ce4arab.com/vb7/images/sub/10_2016/18021243am-1171831-240837-5092424-631810.jpg[/url] [url]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171832-240837-5092424-631810.jpg[/url] [url]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171833-240837-5092424-631810.jpg[/url] [url]http://www.ce4arab.com/vb7/images/sub/10_2016/18021244am-1171834-240837-5092424-631810.jpg[/url][/QUOTE] شكرا اخوي سأقوم بالتجربه ان شاء الله |
مشكور على هالطرح
Android N ◦ Viper10 4.0.0 Beta | 2.28.401.6 ◦ Tweaks | HUB | OTA
[IMG]http://www.ce4arab.com/vb7/images/sub/11_2016/25075241am-1175627-240837-5094265-631810.png[/IMG]
النسخة تجريبية لأنصح بها الأن حتى تكون أقصر استقرار وحل المشاكل المتعلقة بالريكفري المعدل TWRP بعض مشاكل الروم - التحديث علي firmware القديم سيعطل حساس البصمة كصفحة بدء حتى تقوم بإعادة تعين له -الـ firmware الجديد سيقوم بتعطيل الريكفري المعدل TWRP وأمور أخرى للتحميل [url]http://venomroms.com/viper10-downloads/?refresh=true[/url] |
انا محمل الاصدار الرابع جميل جدا وبالنسبه للبصمة قامو باصلاح العطل
تروح لبرنامج venom hub وتروح لقسم downloads وتختار addons وتختار fixes وتختار enable fingerprint on old firmware وتضغط download وراح يحمل ويعيد تشغل الهاتف وتشتغل البصمه ✌ |
[QUOTE=zman__alsmt;5103479]انا محمل الاصدار الرابع جميل جدا وبالنسبه للبصمة قامو باصلاح العطل
تروح لبرنامج venom hub وتروح لقسم downloads وتختار addons وتختار fixes وتختار enable fingerprint on old firmware وتضغط download وراح يحمل ويعيد تشغل الهاتف وتشتغل البصمه ✌[/QUOTE] هل قمت بعمل مسح للذاكرة بسبب الغاء تشفير الذاكرة ? Sent from my HTC 10 using Tapatalk |
لا والله ما اعرف ومسببه لي مشكله ما اقدر اغير الروم
[ROM] 09/12 Viper10 4.2.0 | 2.28.401.9 ◦ Tweaks | HUB | OTA
ROM 09/12 Viper10 4.2.0 | 2.28.401.9 ◦ Tweaks | HUB | OTA ◦
هي أول الإصدارات الثابتة بعد اصدار 3 رومات تجريبية سابقة وعلاج مشكلة الريكفريف المعدل قبل تحميل الروم يجب الإطلاع على [URL="http://www.ce4arab.com/vb7/showpost.php?p=5107292&postcount=9"]هذا الموضوع [/URL] التحديثات الأخيرة [CODE] Additions & Updates Rebased to 2.28.401.9 Hiding Persistent notifications (lets you hide them, without disabling other notifications of the app) Different options how to show the (full) alarm in your statusbar header Expanded only (stock) Collapsed only Expanded and collapsed state Hide both Always show toast with time for caffeine tile Hide slow charging notification Custom Homescreen layouts 4x5, 4x5, 5x5 (works not on small display size, there 5x5 is fixed) Fixes & Cleanups Fixed bundled notification row not getting themed Fixed notifcations with children not getting themed (happend for mail/message apps when several unread notifications were present) Fixed appdrawer not flinging from page two to one when blinkfeed is disabled Fixed neqs not expanding Fixed toggle to disable keep quick neqs collapsed not working Fixed Ambient Display not working Disabled SystemInfo circles for now Viper10 4.1.0 (06 December) Additions & Updates US Unlocked Support (Fullrom only) - Enables VoLTE, WiFi Calling SuperSU option: Works better for some apps, but breaks safety net. Enabled camera panorama selfie mode (Fullrom only) Headsup notification configuration works now InCall Headsup notification - Replaces the fullscreen caller Option to make InCall Headsup notification clearable (you can swipe it away without dimissing the call) Region Screenshot Statusbar theming is back Enabled Systemui tuner Added Navbar Tuner Added Nightmode/Color filter option Notification theming complete now - color for footer can be set. Added option to show DND on volume panel Volume DND panel gets themed with volume backgroud color and NEQS text color (same DND panel is in NEQS) Custom button light values per light sensor value Button and flashlight notifications Venomnavbar is back with extended navbar Hide options for stock navbar and venomnavbar (auto hide, touch anywhere to hide, shortpress, longpress hide) Color options for navbar working now Header options are back Aligned header views with other content in the header Decreased default infoline text size Infoline textsize configurable now There are some bugs still with the header options..those will be fixed hopefully till next weekend - For people that can't live with the broken animation when expanding neqs can revert the statusbar of the previous release. Force enabled call recording Fixes & Cleanups Fixed OTA - works just for people on old firmware running decrypted. Get that ****ing TWRP running @nkk71 , @topjohnwu and @beaups :P Fixed distorted statusbar notification count Fixed screenshot button mapping causing shell to reboot Fixed selecting custom lockscreen weather location fcing VenomTweaks Fixed hidden battery reappearing after statusbar reboot/reboot Button light notifications Fixed lights getting turned off although its set to always on in the native settings when using button light notifications. Fixed lights staying on and draining battery after timeout hits Fixed VenomSideBar force closing when trying to access the setttings Viper10 4.0.0 Beta Preview (24th November) Additions & Updates Rebased on 2.28.401.6 Android N base Magisk support, thx @topjohnwu Rooted with phh superuser by @phhusson (SuperSu didn't let the rom boot) Some additions to customize the new quicksettings [/CODE] [URL="https://drive.google.com/file/d/0B3QSQAudq2MWSWVuYW5CMnFYMW8/view?usp=sharing"]رابط الروم [/URL] |
تسلم يا غااااالي
جميع الأوقات بتوقيت GMT +3. الساعة الآن 09:01 PM. |
