قديم 01-12-2011, 12:39 PM   #151
Abu-sama
مشاركات الشكر: 153
شكر 197 مرات في 102 مشاركات
المشاركة الأصلية كتبت بواسطة hema1 مشاهدة المشاركة
رابط تحميل النسخة 29
Download Turkbeyromv29.zip from Mirrorcreator - Upload files to multiple file sharing sites
V29 2.3.6 XWKK5
All features are included in V28
Siyah Kernel 2.3 Final
13.2 New Jkay Mode
Simplified and changed some of the icons on the notification screen
Change was made to some of the icons in the System.
Added Tw4.5 beta 22 and changed some icons
Tw4Manager added the latest version of the system.
Added Google Maps 6.0
Upgraded Social hub new version.
Added Dsp Manager
Added Maxthon Browser
Added Tw calendar widget
Added Barcode Scanner
Current integreted Adobe Flash current
Added Compass
Microbes and AsusWater live wallpapers added to the system
System performance was achieved and stability adjustments
Full Screen Caller standard
JKAY MOD 13.2
Features in v13.2 (bold is added since v13.1):
* Volume Lock (on/off toggle: a deluxe setting that will make sure notification volume is the same as ringer volume).
* Added Status bar 'Themed clock but only when Fully Connected' toggle on/off: Makes clock and battery level green or whatever the theme color is when fully connected to google servers.
* Added Status bar battery icon on/off toggle
* Added Status bar alarm icon on/off toggle
* Added Status bar silent vibration icon on/off toggle
* Added Home button haptic feedback on/off toggle
* Added Status bar 'Themed clock' toggle on/off: Makes clock and battery level green or whatever the theme color is (blue, gold...)
* Added Status bar 'Battery level' toggle on/off: show/hide battery percentage next to battery icon
* Added 'No lock screen' option as lock screen selection.
* Added Custom/Temporary Screen time-out quick panel toggle called 'Screen on'. Temporary will set your screen time-out to a value between 1 and 210 minutes and reset back to original timeout at screen off.
* Added Quick Launch Panel: Fully customizable quick launch panel (as a toggle, select and/or reorder launch buttons - including Reboot, Recovery, Download and Power off)
* Fully customizable quick settings panel (select and/or reorder quick setting buttons)
* Added: Auto collapse statusbar on/off
* Added: 6 button quick panel on/off
* Removed padding code from sound toggle
* Changed the default shortcuts on lock screen (now only Unlock and Sound toggle at center, so glass left, right and up will all be unlock and down will be silent)
* Added Flashlight toggle to quick panel (it keeps screen on! So remember to turn it off using button or power button)
* Added Auto brightness toggle to quick panel
* Added Secure toggle to quick panel (your unlock screen will switch to your selected lock screen while not secure)
* Fixed vibration toggle on quick panel and Phone options dialog (now switches correctly according to vibration state: always off, always on, only in silent mode, only if not in silent mode)
* Toggle for Bluetooth On notification
* Toggle for status bar vibrate icon (show only when in silent mode)
* Toggle for lock screen charging info
* Toggle for lock screen next alarm info
* Toggle for lock screen date
* 'Next Alarm' information on lock screens
* Use AOSP clock style on all deluxe lock screens (as a toggle)
* Long date format on all deluxe lock screens (like Monday, 26 September as a toggle)
* Charging information on all deluxe lock screens
* Center clock, date and charging info on all deluxe lock screens (as a toggle)
* 2 lock screens (JKay Glass Deluxe and JKay AOSP Deluxe)
* Support for Transparent wallpaper!
* Support for Live Wallpapers on Unlock screens (pattern/pin/password)!
* A toggle to remove leading zero of the clock on the lock screen
* A toggle to remove the quick button text (requires reboot)
* A toggle for CRT TV on effect (bypassing Animation setting!)
* A toggle for CRT TV off effect (bypassing Animation setting!)
* A toggle to hide the clock from statusbar (move it over next to date)
* A toggle to remove the carrier label from the notification bar
* 'Show lock screen when secure' toggle (shows AOSP/Glass lockscreen before unlock screen aka pattern/pin/password)
* Support for Skipping music track/fm radio station using vol-up/down-keys when screen is off (as a toggle)
* 15 seconds timeout... (as a toggle)
* Flashlight on/off toggle from both JKay Deluxe lock screens (5 mins timeout)
* Sound on/off toggle from both JKay Deluxe lock screens
* Screenshot from the Power options dialog
* Full charge notification on/off toggle
* Low battery notification on/off toggle
* Confirm shutdown on/off toggle (asks for confirmation when using Reboot, Recovery, Download and Power off)
* Support for custom launch actions from lock screens
* Support for custom icons on JKay AOSP Deluxe lock screen
* Support for disabling Home button double click
* Support for home screen wallpaper on lock screen (use live wallpapers on the lock screen like on the good old SGS!)
* Support for lock screen clock on/off
* Support for no Unlock animation
* Long click quick panel buttons will launch respective settings menu
* Horizontal scrollable quick panel with 8 new toggles Data / Flight mode / Sync and Vibrate etc...
* Support for Vibrate on/off when unlocking
* Support for Dark background on/off
* Supports customizable Power Options Dialog
* Supports SIP & VOIP
* Support for WiFi statusbar icon change when fully connected
استمتعوا
هل ينفع التعريب الموجود هنا
http://www.multiupload.com/CF2ZQHUGYR
أو
http://wanamlite.com/wp-content/uplo....KeyBoards.zip
Abu-sama غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون Abu-sama على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 01-12-2011, 01:06 PM   #152
saudifly
الصورة الرمزية saudifly
شكر 193 مرات في 132 مشاركات
جربت التعريب الثاني وشغال تمام
saudifly غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون saudifly على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 01-12-2011, 01:34 PM   #153
hskeik
الصورة الرمزية hskeik
مشاركات الشكر: 25,698
جاري رفع تعريب النسخة 29 مع الكيبورد, الانترنت عندي تعيس.
الدمج الآلي للمشاركات المتعاقبة التي لم يكن بينها 24 ساعه --------- هذه المشاركة اضيفت في 01:34 PM ----------- المشاركة السابقة اضيفت في 01:22 PM ---------
http://www.multiupload.com/FFAWSG2IQU
عدد 5 من الاعضاء يشكرون hskeik على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 01-12-2011, 07:02 PM   #154
mohtadi
مشاركات الشكر: 128
شكر 364 مرات في 126 مشاركات
مُبهرٌ هذا الروم ومُبهرٌ صاحبه
mohtadi غير متصل   رد مع اقتباس
العضو التالي يشكر mohtadi على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 01-12-2011, 09:11 PM   #155
baghdad2010
الصورة الرمزية baghdad2010
مشاركات الشكر: 90
شكر 255 مرات في 111 مشاركات
الروابط غير فعالة ؟؟؟
baghdad2010 غير متصل   رد مع اقتباس
العضو التالي يشكر baghdad2010 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 01-12-2011, 09:38 PM   #156
alhanon01
مشاركات الشكر: 40
شكر 42 مرات في 24 مشاركات
الرووووووم في قمة الروعه يارب بس ان البطاريه تكون بعد حلوووووووو
مشكور اخوي hskeik على التعريب
وعقبال التعريب الكامل للروم
alhanon01 غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون alhanon01 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 03-12-2011, 01:45 PM   #157
khedir
الصورة الرمزية khedir
مشاركات الشكر: 68
شكر 620 مرات في 347 مشاركات
ياريت يا أخوان إدراج نسخة الروم TurkbeyRom V29 على اي سيرفر تحميل آخر
الروابط الخاصه بتحميل الروم غير مجزيه
.. العنوان غير صحيح ..
( لم أجد رابط التحميل ) ولم أوفق في تحميل الروم
أرجوا إدراج الروم على رابط فعّال
كما أرجوا تكرماّ من المشرفين الأفاضل المتابعه لمد يد العون
khedir غير متصل   رد مع اقتباس
العضو التالي يشكر khedir على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 03-12-2011, 06:32 PM   #158
رعش قلبي
شكر 145 مرات في 114 مشاركات
اممممممممممممممم ما ادري بس 26 احلا في الانتقال
رعش قلبي غير متصل   رد مع اقتباس
العضو التالي يشكر رعش قلبي على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 03-12-2011, 10:17 PM   #159
khedir
مشاركات الشكر: 68
Up
للــــــــــرفــــــ ــــــــع
قديم 04-12-2011, 12:18 AM   #160
MooDeeY
الصورة الرمزية MooDeeY
مشاركات الشكر: 88
شكر 1,030 مرات في 355 مشاركات
المشاركة الأصلية كتبت بواسطة khedir مشاهدة المشاركة
تفضل رابط روم 29
http://www.hlusoe.info:5000/hotfile/...kbeyromv29.zip
وللعلم نزل اصدار أحدث 29.1
http://www.hlusoe.info:5000/megauplo...eyromv29.1.zip
بعد التحميل الأفضل تعمل اعادة تسمية للروم الى مسماها الاصلي بمعنى تحذف hlusoe.info_ من الإسم سواء نسخة Turkbeyromv29.zip او نسخة Turkbeyromv29.1.zip
MooDeeY غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون MooDeeY على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 04-12-2011, 12:33 AM   #161
alsalemmm
مشاركات الشكر: 28
شكر 30 مرات في 24 مشاركات
يا اخوان ايش الهرجه
كل يومين ثلاثه ينزل روم
اللحين نزل الروم المطور 29.1 من الروم الاخير 29
ابي اعرف ايش الفروق
alsalemmm غير متصل   رد مع اقتباس
العضو التالي يشكر alsalemmm على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 04-12-2011, 12:56 AM   #162
MooDeeY
مشاركات الشكر: 88
الفرق تركيب كيرنال صياح الاخير واصلاح بعض مشاكل التعليق بالروم 2.9 وتغيير الدايلر وترقية السوبر يوزر لاصدار احدث وتغيير بعض الايقونات اللي كانت بها مشاكل وتركيب ايقونات جديده داخل مشغل الصوتيات وغيره وتركيب تويك خاص بالروم يحتوي على التحديثات والثيمات والويدجت المتوافق مع الروم . هذا اللي لاحظته , تو مركب الروم من دقايق
قديم 04-12-2011, 06:53 AM   #163
khedir
مشاركات الشكر: 68
MooDee
الله يرحم والديك ويجزيهم ويجزيك الجنه يبن الاكرمين
أخي الكريم .. ماذا بخصوص التعريب .. ؟
هل بالإمكان إدراج رابط التعريب المناسب لهذا الإصدار .. ؟ تكرماً
شكـــــراً أخــــــرى
قديم 04-12-2011, 08:52 AM   #164
mazen2x2
الصورة الرمزية mazen2x2
مشاركات الشكر: 1,511
شكر 2,243 مرات في 1,183 مشاركات
طلب عاجل
أرجوا المساعدة أريد الثيم أو الآنشر الموجود على الروم في أول المشاركة
الأصدار v26 الموضح بالصورة
(روم)( للجلاكسي اس 2) SGSII_I9100 TurkbeyRom V37 SE No Wipe JkayMod(13.6.3)-2.3.6 XWLA4 NEAK KERNEL 1.3.3X
أرجو من الجميع الأهتمام في طلبي هذا والمساعدة
mazen2x2 غير متصل   رد مع اقتباس
العضو التالي يشكر mazen2x2 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 04-12-2011, 10:35 AM   #165
MooDeeY
مشاركات الشكر: 88
MooDee
لا يوجد تعريب خاص بهذا الاصدار
ولكن يمكنك تشغيل هذا التعريب فهو متوافق بشكل جيد ولا يوجد به أي مشكلة
http://www.ce4arab.com/vb7/showpost....&postcount=119
العضو التالي يشكر MooDeeY على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 04-12-2011, 11:10 PM   #166
khedir
مشاركات الشكر: 68
أشكرك كل الشكر أخي الكريم MooDeey على مساعدتك وحثيث سعيك
والروم قليله فيه مفـردة ( ممتاز ) بل هو أكثر من ذلك بكثييييــر
تم تحميل هذا التعريب
والحمدلله ممتاز .. وفي صدد مراقبة فعاية الروم مع البطارية
قديم 04-12-2011, 11:20 PM   #167
ميسروب
السﻼ م عليكم لدي مشكلة صغيرة في هذه الروم وهي بان التحزير للرسائل القادمة ﻻ يعمل لكن التحزير للمكالمات القادمة يعمل مع العلم لدي برنامج bln pro للتحزير عند المكالمات و الرسائل الغير مجاب عليها. هل احد اخر لديه هذه المشكلة غيري. ارجو حل لهذه المشكلة و شكرآ.
ميسروب غير متصل   رد مع اقتباس
العضو التالي يشكر ميسروب على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 05-12-2011, 12:22 AM   #168
aim0005
مشاركات الشكر: 58
شكر 231 مرات في 95 مشاركات
المشاركة الأصلية كتبت بواسطة 2x2 مشاهدة المشاركة
http://www.ce4arab.com/vb7/images/su...011/596888.png
تفضل يا حلو ....
طريقة التركيب : تتم عن طريق الريكفوري
Change SBTIcone.zip
aim0005 غير متصل   رد مع اقتباس
العضو التالي يشكر aim0005 على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 05-12-2011, 08:01 AM   #169
mazen2x2
أشكرك أخي aim0005 على متابعتك ولك مني كل أمتنان وتقدير
قديم 05-12-2011, 11:14 PM   #170
khedir
مشاركات الشكر: 68
الروم بسخـــة 29.1
بعد عمل 12 ساعه على وضعية H + Data إستنزفت فقط 32% من البطاريه
مع عمل برنامج الـ وتس آب + تحميل برامج وكذلك تحديث بعض البرامج في الأثناء
وضعية ضوء الشاشه على أوتوماتيك + تشغيل خاصية تسجيل صوتي لمدة 57 دقيقه
والنتيجه :
إستنزاف فقط 32% .. وبقي 68% من عمــر البطاريـــــــه !!!!
أنصح بتجربة الروم
عدد 2 من الاعضاء يشكرون khedir على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 06-12-2011, 11:11 AM   #171
khedir
مشاركات الشكر: 68
رابط تحميل التعريب للنسخــة 29.1
متصفح وقرائه وكتابه وكيبورد !
ملاحظة هامة:
اذا ركبت اي روم ولاحظت صرف غير طبيعي للبطارية اعمل وايب داتا ووايب كاش وان لم ينفع معك .. لازم تعمل وايب وتفرمت الذاكرة الداخلية وستلحظ فرق كبير جدا
قديم 07-12-2011, 10:22 AM   #172
عبدوس القدرة
الصورة الرمزية عبدوس القدرة
مشاركات الشكر: 51
شكر 138 مرات في 88 مشاركات
شباب انا حملت الروم وصراحة روعة بس ملاحظ انه يصرف بطارية (علي عكس ما جربتوه انتم)
ايش برايكم يكون السبب ؟ صراحة حيرني
عبدوس القدرة غير متصل   رد مع اقتباس
العضو التالي يشكر عبدوس القدرة على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 07-12-2011, 02:38 PM   #173
khedir
مشاركات الشكر: 68
المشاركة الأصلية كتبت بواسطة عبدوس القدرة مشاهدة المشاركة
قديم 07-12-2011, 04:16 PM   #174
ccfan88
الصورة الرمزية ccfan88
مشاركات الشكر: 32
شكر 23 مرات في 18 مشاركات
كيف عمل فرمته للذاكره الداخليه؟
ccfan88 غير متصل   رد مع اقتباس
عدد 2 من الاعضاء يشكرون ccfan88 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 08-12-2011, 12:29 AM   #175
arome89
الصورة الرمزية arome89
مشاركات الشكر: 9,886
تركي بي نسخه جديده قادمه قريبا وبمميزات افضل
اول ميزه هيه دوران الشاشه مثل جلاكسي نوته والايفون !
Screen Rotation Animation
الميزه ثانيه وهيه مأخوذه من سوني ارسكون Sony Bravia Engine وهيه لاعطاء الصور والفديوات وضوح ونقاوه افضل
تم رفع الروم وتحياتي لكم
Download TurkbeyRomv29.2newbraviaengine.zip from Mirrorcreator - Upload files to multiple file sharing sites
UPLOAD TOMORROW
Siyah KERNEL 2.4+ Final
Pda : I9100XWKK5
Phone : I9100XXKI4
Csc : I9100OXXKJ3
Created new framework and new system files
Changed Tw4.5 the red point,to blue point
Added transparent Tw4.5 folders
Added New live wallpapers
Changed the default boot-up wallpaper and screen lock.
Changed the icon for some applications in the system.
Some errors in the previous version are fixed.
RAM usage has been reduced.
Samsung full weather application on request re-transparent icons with the new season.
Files folder has changed.
الموضوع الخاص بسوني برافيا
Added Sony Bravia Engine ( Thanks GadgetCheck )
http://forum.xda-developers.com/show....php?t=1380094
الموضوع الخاص بدوران الشاشه
Screen Rotation Animation ( Thanks imparator )
http://forum.xda-developers.com/show....php?t=1362354
وهنا الفديو يضهر كيفيه دوران الشاشه ولا اروع
Galaxy s2 fancy rotation animation | فzlesene.com Video
عدد 4 من الاعضاء يشكرون arome89 على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
للجلاكسي, android, bluetooth, الايسكريم, البطارية, الريكفري, الواي فاي, تحميل, galaxy, galaxy s, galaxy s 2, galaxy s ii, google, launcher, روم, sony, unlock, update, youtube, نوت
جميع الأوقات بتوقيت GMT +3. الساعة الآن 12:02 PM.
