قديم 01-01-2008, 09:06 PM   #1
الصورة الرمزية وحيدالدرب
مشاركات الشكر: 2,294
شكر 1,733 مرات في 711 مشاركات
روم جديد للكي جام [31-Dec-2007] XDA Mobile 6 Release 5 FINAL - Full and Lite versions
XDA Mobile 6 Release 5 (XM6r5 for short) is the fifth version (and most likely my last since I now have a Tilt/Kaiser phone) of the popular XM6 rom series for the Wizard. This ROM brings back the stability of XM6r3. There is a Full and Lite version. Also I'm releasing a ng pack so you can build your own version of XM6r5.
XM6r5 is built on the OS 5.2.318 Build 15342.4.0.01 rom that was provided to us by InGeNeTiCs from Howard Forums. While this is not the "newest" release of WM6, it is the last known release that was built for the Wizard (ie: its not a port from another HTC Device). Various pieces of the base rom have been upgraded, so some of it is stuff ported from other phones so that it can have newer functionality. Overall, I feel this base is very stable and fast and makes a great base to cook on.
Please Note: this ROM was NOT intended to push the limits on speed optimization or memory optimization. It was made to be functional, stable, and something that I myself wanted and will use. If you have a Battery Drain issue, make sure you flash back to an official rom before you upgrade to this one, as that should correct extended rom corruption that has been shown to cause battery draining. If you want to overclock or use other features of BatteryStatus, you can download and install the latest version of BatteryStatus. I used it when I had my Wizard, and had OMAP set to 247MHz with CPUscalar set from 143 to 247 and Boost set to 260Mhz.
Base ROM Information
The base rom was an "Official" Wizard WM6 ROM that was part of the development cycle of WM6 inside of Microsoft (Dogfood as they call it). The base rom was not a port of another device rom with drivers and stuff pieced and parted onto this one, but this was an actual Wizard WM6.
Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01
ROM Version: 10.1.0.811 WWE
ROM Date: 08/11/06
Protocol: 4.1.13.09
PagePool: 6MB
There is no Radio, IPL, SPL or Extended ROM included in this (so its G4 "safe").
What's In XDA Mobile 6 Release 5?
Bolded items are new / upgraded from XM6r4
Lite and Full
.NET CF 3.5
Aserg's Touch Scroll Only
HTC TOUCH Dialer with enhanced keypad numbers by peu
HTC Voice Recorder
PPC Contacts Manager
Internet Sharing via BlueTooth DUN (like WM5); WM6 Internet Sharing is still there, the BT DUN is in addition to that!
Office 2007
9 Button "Touch" Style CommManager from the Kaiser
VoIP (See next post for instructions to set this up)
SQLCE
Arcsoft Composer 4.2.8.1 (SMS and MMS are split apart and not merged) The bug in r4 has been corrected in r5
Notepad editor
Pocket RAR
SIP Config
Total Commander Beta 2.5 Beta 3
PIM Backup to 2.5
Oxios Memory
Windows Live Search searches via Google
SIM Manager
dotFred TaskManager (with registry editor link setup and associations built in for .reg files)
delayedexec.exe is in \Windows but is not configured. See this post for details on using this.
Mortscript 4.1
PeekPocket 1.5
MoDaCo NoData (so you can turn off data sources)
Camera 3
Full version also contains:
WkTask 1.1.7.3b (Latest Version)
HButton (Enable multiple apps on hardware buttons)
HTC Action
WMP Touch style skin
QuickMenu
MortPlayer
Schap's Advanced Configuration Tool v1.1 and VoIP Setup Tool
SK tsync (Time Synchronization)
Esmertec Java Manager (replaces the standard Midlet Manager)
WM5torage 1.78Beta4
WinXplore 0.4
Blue / Gray Onscreen Keyboard
20 Onscreen Keyboard skins that you can choose to use!
Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone)
StartClean
PocketScreen (Screen Capture tool)
1-Calc Lite
Smartskey 0.60 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6)
DotFred's SoftKeyAppletEx
WM5NewMenu
BT Crawler
Call2Contact
Freecell (a Solitaire card game)
Tetris - game
The following items that were in XM6r4 have been removed in XM6r5
REMOVED: FingerFriendlyFriends This is now a commercial product
REMOVED: TodayAgenda 1.0 Due to a bug in r4 - Install via cab and the bug doesn't happen.
REMOVED: Adobe Reader LE
REMOVED: Battery Gauge - WkTask now does this
REMOVED: SuperDoku v1.1 - Install via cab now
Mods made in XM6r5 (Lite and Full versions)
In addition to the apps listed above, the following fixes and mods were made to improve the user experience on XM6r5
Changing ringtone now stays changed when you leave the Phone app
Using press and hold on CommManager button toggles vibrate on and off, and phone does NOT stay stuck in vibrate / no ring mode
Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy)
Menu sounds work by default
Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect
Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix)
D pad now works differently with PIE. Up and down presses on the D Pad stay the same, but pressing right jumps forward a page and pressing left jumps backwards a page. Makes going through websites easier (IMO).
Fixed the A2DP registry for sampling
Registry Entries for PIE Connections to speed page loading
Registry Entries to increase In Call Volume
Press Button 1 for messaging (like normal) or hold it a little longer and HTC Action will come up (via HButton)
WkTask setup to not show Phone and Activesync as running apps in task bar
QuickMenu enabled for nice drop down and cascading start menu
Touch Scroll only is active so use your finger to scroll in most places
Button 4 starts the WkTask Launcher by default. Press and hold Button 4 to start Voice Recorder app
ROM now remembers new words in custom dictionary
Fixes found in XM6r5 RC1 have also been implemented in this Final version
نأتي لروابط التنزيل
XM6r5 Full Version
http://www.savageground.com/download...zard/XM6r5.zip
XM6r5 Lite Version
http://www.savageground.com/download.../XM6r5Lite.zip
This cab does the following:
Updates PIM Backup to 2.7
Changes WkTask left and right setting so it doesn't hide VoiceMail (and similar) notification icon
removes the tools folder icon from the Windows folder
Changes the Wait Cursor to be the Touch one
Change Start->Settings->System->About to show XM6r5 instead of XM6r4
Fixes Smartdialing Options in the dialpad menu
Add default registry entries so when (if) BatteryStatus is installed, Phone and Camera are set to 195Mhz
Make PocketRAR the default app for .zip files
You will need to soft reset after this install completes
http://forum.xda-developers.com/atta...d=1199 138847
رابط الموضوع الاصلي
http://forum.xda-developers.com/showthread.php?t=355591
وحيدالدرب غير متصل   رد مع اقتباس
عدد 3 من الاعضاء يشكرون وحيدالدرب على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
اخر 5 مواضيع للعضو وحيدالدرب
مشكلة في جهاز note 1 قسم ترقيات الأجهزة الأخرى بنظام Google Android وحيدالدرب 4 1872 20-11-2012 03:14 PM
قديم 01-01-2008, 10:48 PM   #2
wisambanat
مشاركات الشكر: 695
شكر 1,131 مرات في 131 مشاركات
يشرفني اكون اول واحد يرد عليك بالموضوع واشكرك الف شكر ويعطيك الف عافية
والله يقويك
wisambanat غير متصل   رد مع اقتباس
قديم 01-01-2008, 11:59 PM   #3
samery
خبير الاجهزة الكفية
الصورة الرمزية samery
الرتبة الادارية: مشرف مساعد
مشاركات الشكر: 2,514
شكر 5,223 مرات في 1,754 مشاركات
بإنتظار التجربة والإفادة من الاخوان.
يرجى قرائة المعلومات كلها في المشاركة اعلاه لانها بعضها مهم عن هذا الروم وشكرآ
samery غير متصل   رد مع اقتباس
العضو التالي يشكر samery على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 02-01-2008, 07:41 AM   #4
وحيدالدرب
هذي صور للروم
19805.imgcache
عدد 2 من الاعضاء يشكرون وحيدالدرب على مشاركته الطيبة ويطلبون المزيد من هذه المشاركات الرائعة ويدعون له بالتوفيق
قديم 04-01-2008, 07:18 PM   #5
drbatman
مشاركات الشكر: 42
شكر 13 مرات في 11 مشاركات
يرجي من الخبراء و المشرفين ابداء رأيهم في هذا الروم الجديد من حيث المزايا و العيوب و استقراره مع مقارنته مع TNT1933 حيث انه اخر روم للK-jam و جزاكم الله كل خير
drbatman غير متصل   رد مع اقتباس
قديم 04-01-2008, 08:05 PM   #6
nice_shape
مشاركات الشكر: 271
شكر 200 مرات في 84 مشاركات
جزاك الله خير .. ودي اجربها ..
بس من كلامه الظاهر أنه مستقرة فقط ولا يطمح لأن تكون سريعة :\
nice_shape غير متصل   رد مع اقتباس
قديم 04-01-2008, 08:53 PM   #7
wssherbiny
الصورة الرمزية wssherbiny
مشاركات الشكر: 213
شكر 166 مرات في 41 مشاركات
المشاركة الأصلية كتبت بواسطة drbatman مشاهدة المشاركة
لقد جربت هذا الإصدار و سبب مشاكل مع ال resco و عدم استقرار في الجهاز
فقمت بالرجوع الى ال TNT في نفس اليوم
و من تجربتي معه لا أنصح به
wssherbiny غير متصل   رد مع اقتباس
قديم 05-01-2008, 12:52 AM   #8
منير النائر
مشكوووور يا أخي وجزاك الله خيرا.
أود أن أعرف ما إذا كان بمكن استخدام هذا الروم مع jasjam وكيف الترقية إلى TNT؟
بارك الله فيكم
منير النائر غير متصل   رد مع اقتباس
قديم 05-01-2008, 02:59 AM   #9
وحيدالدرب
اخوي هذا الروم للكي جام وهماك موضوع مثبت للجاسجام وطرقة فك الحماية وموجود اخر تحديث له وهوTNT SE
العضو التالي يشكر وحيدالدرب على مشاركته الطيبة ويطلب المزيد من هذه المشاركات الرائعة
قديم 13-06-2016, 05:16 PM   #10
ebnelarab
الصورة الرمزية ebnelarab
شكر 40 مرات في 35 مشاركات
الروابط لا تعمل
ebnelarab غير متصل   رد مع اقتباس
bluetooth, dialer, gprs, htc, launcher, mms, روم, rom, sms, usb
جميع الأوقات بتوقيت GMT +3. الساعة الآن 07:29 PM.
